chilly0013
Hi all,
I have recently purchased 2 Technics SL-10, both are in great shape and work good, but I wanted to make sure they were as close to factory settings as possible. SO I cleaned everything, re-lubed all the parts and followed the instructions in the Service manual except the 1mm pitch record adjustment. I will be keeping one of these and selling the other, so I want to make sure they are as perfect as can be.
So I have some questions:
step 1: done I have aligned the tonearm to the housing
step 2: when I move the tonearm all the way to the right, I get 4.7 volts, not 7.6 (is this an issue?)
step 3: when I move the tonearm all the way to the left, I get .3 volts
step 4: based on the above results the calculation I get is 2.6 volt, so I adjust the 1.5mm socket screw to 2.6
step 5: adjust R449 to .72 volts
step 6: since I do not have the 1mm pitch record, I do have an album with a lead out groove at 5mm, but do not know what to adjust R447 to, currently I have it at .5 volt
SO things I have noticed:
the tonearm is not aligned with the illuminated pointer, it is about 2-2.5 mm to the right when playing a record, If I adjust the alignment (step 1) then it is not parallel with the tonearm housing. Is this a problem with it being lagging behind the pointer?
When the tonearm lifts at the end of the record, it does not settle back in the V-groove, so when you play the next side it actually starts a few grooves into the song, then it settles in the v-groove. If I pay attention I physically nudge the tonearm to the v-groove when I flip sides. Is there a way to fix this?
It seems that the above 2 things maybe related to the bearings of the tonearm, but there are no instructions on fixing that.
Thoughts?
Thanks in advance for all your help
-kev
Thoughts?
-kev
