shnaggle
According to vinylengine.com, these are the SL-1200 mk2s specs:
Specifications
Type: manual turntable
Drive method: direct drive
Motor: brushless DC motor
Control method: servo (mk1), quartz (mk2)
Platter: 330mm 1.75kg (mk1), 332mm 2kg (mk2)
Speeds: 33.33 and 45rpm
Wow and flutter: 0.03% WRMS (mk1), 0.025% WRMS (mk2)
Rumble: -70dB (mk1), -78dB (mk2)
Tonearm: universal
Effective length: 220mm (mk1), 230mm (mk2)
Overhang: 14mm (mk1), 15mm (mk2)
Effective mass: 12g (mk2)
Stylus pressure range: 0 to 4g (mk1), 0 to 2.5g (mk2)
Dimensions: 453 x 366 x 180mm (mk1), 453 x 360 x 162mm (mk2)
Weight: 10kg (mk1), 12.5kg (mk2)
And these are the specs for the SL-Q2:
Specifications
Type: semi automatic
Platter: 312mm aluminium alloy
Speeds: 33 and 45rpm
Motor: quartz controlled (direct drive)
Wow and flutter: 0.025% WRMS
Rumble: -78dB
Tonearm: static balance, tubular
Tracking force adjustment: 0 to 2.5g
Effective length: 230mm
Dimensions: 430 x 130 x 375mm
Weight: 6.9kg
Besides the obvious, that the SL-1200 has variable pitch control and the SL-Q2 does not, is there a significant performance difference between the two, very differently-priced, models?
Specifications
Tonearm: universal
Specifications
Rumble: -78dB
Weight: 6.9kg
