Many here talk about the
KAB upgrades. Which one(s) of these upgrades provide the best bang for the buck for a new SL-1200? Or what is the preferred "upgrade path"?
Not that I would drop $2,000+ of upgrades into a $400 TT, mind you - just curious.
- A. 78 RPM Speed $175 MK2 and MK5 Only [more info]
- B. TD-1200 Tonearm Fluid Damper $149.00 [more info]
- C. PS1200 Power Socket (For Future PS-1200 Connection)$45.00
- D. PS-1200 Outboard Power Supply( Includes Socket Above ) $250.00 [more info]
- D. PS-1200 220V Outboard Power Supply( Includes Socket Above ) $250.00 [more info]
- E. RC-1200 Threaded Record Clamp $149.00 [more info]
- F. KAB USA Record Clamp $29.00 [more info]
- G. SX-1200 Strobe Disabler $50.00 [more info]
- H. Cardas AGMO Connectors $39.00 [Put Hi Quality Cardas RCA's Onto Existing Technics Cable]
- I. Eichmann Tellurium Bullet Connectors $49.00 [Put Hi Quality Eichmann RCA's Onto Existing Technics Cable]
- J. Tonearm Rewire $169.00. Cardas to KAB PC-1200 RCA Phono Plate[2 RCA Females plus ground post]
- K. Tonearm Rewire $169.00. Cardas to KAB/Cardas 5 pin DIN Phono Plate[This Requires right angle DIN connector]
- L. Goldring 1022GX Audiophile Cartridge $239.00 [more info]
- M. KAB/Ortofon Concorde Pro S30 Integrated Cartridge $239.00 [more info]
- N. KAB/Stanton Discmaster V3 AE Cartridge $179 [more info]
- O. Isonoe™ Machined Sorbothane Spring Isolator Feet $200 [more info]
My SL-1200M5 is equipped with:
[*]A. 78 RPM Speed $175 MK2 and MK5 Only [more info]
[*]B. TD-1200 Tonearm Fluid Damper $149.00 [more info]
[*]D. PS-1200 220V Outboard Power Supply( Includes Socket Above ) $250.00 [more info]
[*]J. Tonearm Rewire $169.00. Cardas to KAB PC-1200 RCA Phono Plate[2 RCA Females plus ground post]
Although I use a Technics SP-15 for most of my 78rpm/historic disc playback, I wanted that capability on the new turntable as well. It works well and the adjustable pitch allows you to spin 80 rpm and 76.59 rpm discs at the correct speed.
The tonearm fluid damper is especially beneficial when playing warped discs. It's hard to tell, but when I installed it (nothing more than adding silicone fluid) and did a before/after test on the same LP, it sounded a bit better with the modification.
I could not discern a difference or improvement when I hooked up the outboard power supply. That's not to say there isn't one, I just didn't hear it.
As for the tonearm rewire, I had no way of hearing a before/after effect as it came out of the box rewired.
FWIW, it's a very fine sounding turntable and a joy to use.
