sepehrfarz
I have recently acquired a SL-1300 mk2 turntable. It was all jammed up and was plugged into 220v. I gave it to a technician of sorts and he said he fixed it and there was a broken piece that he "fixed" somehow (I guess it was the infamous cue lever mechanism part). this is my first turntable so I'm not really that experienced. I have 2 problems
- when I play start the tonearm slams into the side of the record goes to start position, comes back to the record but settles just outside of the record.
-When I put the tone arm on the record manually, everything is ok until in reaches the last 1/3 of the record then suddenly pulls inward into the spindle. even when anti skating is put at maximum
My cartridge is an Ortofon super OM with suggested 1.5g weight. I have fully adjusted the tone arm height, weight balance, cartridge is aligned. turntable is level.
