Technics SL-1600 mkII
Rommaster
Marantz 2238B
I recently got a thrift store SL-1600 mkII and i've been trying to get it up to speed so everything works. Platter moves, everything plays without a problem, but it seems to have the notorious cueing problem. I have started to try and get at the area where I install the belt (rubber band), but i can't seem to figure out how the platter comes off. It is different than my sl-1600 (original model) where the platter just lifts off. It seems to be fastened pretty well where it won't just lift off.
What's the trick to this that i'm missing? Do i have to go in from the underside of the unit and remove the bottom cover, or what? Also, if anyone has a service manual or instruction manual scan of the mkII, that would be greatly appreciated. I have the service manual of the original sl-1600 (NOT mkII) that i would be willing to trade. Thanks guys.
The platter just lifts off, it may simply be stuck after all these years, a little alcohol around the post may help. When you get a new belt on if the arm does not drop in the right place there is a rubber plug near the base of the tonearm that covers the adjusting screw. Do remember that the 1600 needs a record in place for the arm to move otherwise the infrared sensors tell the computer that there is no record so don't drop the stylus on the rubber mat.
Rob
Perfect, thanks so much. I just didn't want to force the platter off as it was resisting. It came off fine and i noticed that the cue belt is missing. Can't wait to get her up and running! Thanks so much merrylander, helpful as always :)
And don't forget to use a blue rubberband to replace the belt. Blue just sounds better.
Apologies to Joel of the Turntable Factory down there in the Carolinas; he so wanted us to use proper replacement belts in our Mk IIs that I feel as if I'm betraying him every time I recommend the rubberband gambit. Wonderful guy; I hope he recovers.
A better and still cheap solution is to get a 1/16" thick x 1-1/8" (or 1-1/4") "O" ring at the hardware store. 50 cents and will last longer and work better than a rubber band.
