vinilossolo
Hi. I have a Technics SL-1700 MKII and i have a big problem with it. The cueing system does not work properly. When the arm falls down with the cueing system activated, at the last moment it makes a sudden movement to the left and scratches the record.
It is not the typical problem with the cueing system. In fact, the belt works well, the arm goes up and down and the automatic return mechanism also works well. But i can't find the problem.
When i use the arm manually, i works great. So the problem is only with the cueing system mechanism.
Maybe it`s just lack of lubrication. Someone has had the same problem?
Thanks
Jose
Thanks
Jose
