I would love to purchase a properly cared for vintage tt that does not require constant tuning by someone possessing years of tt knowledge. Simply put, I need something that sounds good, looks good, and is low maintenance. It will be gently used.
I am currently watching for TT's of this class:
Technics SL-1700MK2 (1800mk2 is out)
Thorens TD 125 or 160
Marantz 6300
Denon (need to research the models more)
Yammie (need to research the models more)
Pioneer 530
My concern over the Pioneer from Turntableteen on ePay (this pretty much describes overcomplexity I would like to avoid in a vintage turntable):
PL-530 problems: In order for one of these units to work correct. It has to be serviced. I have 5 in the garage and none function correct. There's two main problems:
1. The brass bushings which secure the tone arm come loose over time which causes wobble.
2. The automatic features work like a Dual or Marantz 6200. Friction based. But with an extra motor which drives the tone arm only... horizontally. This extra motor reduces tracking friction , and is very sensitive. The arm requires cleaning and tuning + at least 5 adjustment points. To enable the tonearm to go back to it's original resting position. The arm may need to be removed from the unit.
3. The controls operate on actual cables. Like bicycle brake cables. Where standard turntables - Marantz 6300 - Technics etc... use wire. The cables are adjustable. (I read somewhere that this may be frequent adjustment).
Again, thanks everyone for helping me on my mission. I should add that I'm doing this for my son also who actually possesses a vinyl collection (Zeppelin genre)... So my next post may be, What is your favorite album on a particular TT? because I really like all varieties of music, but I love discovering the esoteric.
Sorry for wall of text.
