Technics Sl 1900 - headshell & cartridge recommendations
harleyfatboy
Well-Known Member
Picked up a Technics SL 1900 Turntable cheap. Its in nice shape. I know it wasnt anything special as a turntable, but this would just be in another room outside my main system....
It needs a headshell and cartridge....Not wanting to spend much....anyone have some recommendations....
I've seen some cheap headshells on ebay, but not sure what cartridge to even consider....again, not looking to spend much....thx
If you want to go with high compliance (mostly MM / MI ) cartridges - get as light a headshell as possible.
The ADC LMG-1 magnesium headshells that come up regularly on ebay are a good example.
The standard original Technics headshells are marginally heavier, but more readily available.
The knockoff Technics lookalikes tend to be between 1 and 3g heavier.
If you are planning on a lower compliance setup (AT95, most MC's) - a heavier more rigid headshell will work better.
Take a look at http://www.esotericsound.com/ArmsAndHeadshells.htm
The "adjustable azimuth" headshell is a good example of the mid mass heavier headshells I am talking about.
The "low mass sme style" headshell should only be used with high compliance designs - these have a little bit of a tendency to ringiness, so if the cartridge tends towards microphony these may have a problem.
The Technics knockoff looking one is 1.2g heavier than the original Technics - and probably identical to the American DJ headshell - perfectly good middle of the road headshell.
My suggestion for a versatile good performance cartridge is the Shure M97xE - the damper brush provides arm damping which is important - and it is a nice sounding cartridge.
Also provides lots of scope for upgrade (by replacement of the stylus)
bye for now
David
Good cartridge - but it is high compliance - and won't give it's best in a Technics SL arm unless that arm has fluid damping fitted.
(If the TT is a mkII then I believe the KAB fluid damping trough would fit)
But this is likely to be beyond the OP's budget (or am I making a silly assumption?)
Bye for now
David
Thanks - I thought it might be a little costly - but perhaps cheaper say less than 300.00 or so with a different needle. It rocks though.
I did have an older concorde back in 79 on my technicsl sl220 so I thought it would be good. The older concorde is different though.
But - Dialoum is right - make sure you get many opinions on the same cart before pulling the trigger - that is the best advice I can give.
I also have the Audio Technical 440 MLA that I purchased for less than 100.00 - it is a favorite of many.
Good luck!
For starter cartridge either AT95E (or the Shibata/HE versions..) - because it has lower compliance and will mate better with the SL arm.
The Grado Black is higher compliance and quite sensitive to arm stability issues (hence the famous "Grado Dance")
I don't know the compliance of the Red Ed...
The Shure M97xE is also a high compliance design, but balanced out by the damping brush.
So I would support the AT95 & M97xE as the best two options for that arm, within a tight budget.
