I needed a new belt, the old one worked, but had sat so long that there was a "bump" where the belt was around the motor pulley. I could see the strobe "hiccup" when the bump came around. I had to spray the 33 1/3 rpm and 45 rpm potentiometers and then Faderlube them to get the servo nice and stable. I also did the same sprays on the 33 1/3 OFF 45 switch. Without the belt, the platter will spin a long time - didn't pull the spindle shaft for re-lube. An overall cleaning with a natural power clean spray (no ammonia) and soft cotton cloth was needed to get a lot of grime off the dust cover, plinth, etcetera. The stylus cantilever was bent, probably since the arm was not latched and the stylus was bounced around in the thrift store during handing. I bent the cantilever back to a middle position for testing. I bought an original AT stylus after using the straightened one to check out the functionality with an old LP that I use. In spite of the rough handling, the cartridge and table survived and plays nicely.
