Kel_Varnsen
Anyone have a Technics SL-3 Linear Tracker? I found one in a thrift store for $10 a few weeks ago. It was in rough shape but I mostly got it working. I cleaned the whole thing, replaced both broken belts, straightened the wire that stops the tonearm when it moves back to the start, and used contact cleaner on all the controls that were super unresponsive.
The only thing that is still causing issues is the switch that automatically detects a 7". If I put one on the player doesn't recognize and still starts at the 12" position.There is a little lever at the back that detects the record size and it moves fine so I suspect the switch contacts are dirty. The problem is I can't get the cover off to clean them.
I found this thread on Vinyl Engine which shows one removed but I can't figure out how to unlock the hidden locking tabs. The service manual doesn't even mention them.
Anyone have this table and have any luck getting that cover off? With all the other work I've done I would really like to get this last issue fixed.
