drjohnnyfeva
Well-Known Member
So, the first table I ever had was the Technics SL-BL3. It served me well, but when I went to use it - after years of not - as a 20-somthing in the early-90's and it didn't work, having no internet and most places not knowing sh!t about TT's, I fixed it with with a rubber band. Sadly, the wobbly pitch and not knowing where to go or what to do, I put it on the shelf and eventually got rid of it. Fast forward a couple decades and I found one that needed some adjustment, but it was cheap, so I got it and an album in the deal.
Worked pretty well. Cleaned it with DeOxit. Changed the old belt. Got a new cartridge. Sounds great, but rides the vinyl real lightly and there are lots of pops. I thought it could be dirty lp's... cleaned them. Small improvement. Tried a couple static reducing techniques. Again, small improvement.
Finally, today, I taped a small stainless steel washer on the linear arm above the cartridge. The sound output was NOTICEABLE! And a terrific improvement.
So the question... I have no idea what to call that adjustment on a linear tracking TT. I know that you can increase the needle pressure on an arm TT by dialing in or out the counter weight at the end of the arm...
Is there such an adjustment on a linear tracker? Idon't really like the idea of leaving a washer taped to the top of the cartridge, but the experiment was successful, in that it dramatically improved the sound of each LP I played on it.
Help, guidance, and friendly, "You're a dumbass! Get that washer off of your TT!" are all acceptable forms of assistance.
. The extra weight on the headshell is a pretty common tweak people use to match the tonearm effective mass to the cartridge compliance.
