Post subject: Re: Technics SL-D2
PostPosted: Mar Fri 06, 2015 5:11 am
The failure is due to hardened silicone oil in the shaft-and-hollow-cylinder dashpot used for damped cuing. You need to take the cuing mechanism apart from below, clean out the old, hardened silicone oil, and pack it with new silicone oil. You can buy new silicone oil online.
This repair is of medium complexity, and should be attempted only by someone with a fair degree of mechanical savvy. I place the entire turntable upside down on sandbags, with the platter off, so that the set is stable, and so that the weight of the table will not rest on the delicate tonearm gimbal.
There you go.
Fred
owner: Classic Audio Repair, Inc.
