boreas
"If it sounds good, it IS good." E.K.E.
The suspension is a part of the stylus assembly so, if in fact the cartridge (really the orange stylus assembly) is too close to the record and that a collapsed suspension is the cause, a new stylus will cure the problem.
As you suspected, too much stylus pressure can have the same effect so the first thing to do is to verify that the stylus pressure is within the manufacturer's specifications. (If I remember correctly, that's between 1.0 and 1.8 grams.)
Of course, it may be that the cartridge is not riding too low. Cartridges do normally ride fairly low, some lower than others. It might be a good idea for you to post a photo or two of what you're seeing.
John
John
