Technics SL-J2 platter: a compartment? What's for?
catBot
Well-Known Member
Hello!
Technics SL-J2 here.
Right under the mat on the platter there is a comtartment near the spindle as if some electronic module to be placed there.
What could that be?
There should probably be a lever to detect that a record is on the platter, which activates a switch below, and there'd be a second lever detector off to side that detects if it is a 33/13 or 45 size record. This is so it knows where to drop the needle.
Yours may just be missing.
When a major high volume manufacturer produces a range of models some components are shared between them. Like a range of cars, they make the most complex version first and then start removing bits for the lesser models in the range. Main wiring looms etc are all the same - with some plugs and sockets left unused for the lower models. The same applies here.
Example - I have a Sansui Sr-D36 turntable which is direct drive. It uses the same platter as the Sr-D25 which is belt drive. It's more efficient (and cheaper) to produce a single platter that will suit multiple turntable models than it is to to produce specific parts for each unit.
(...) Yours may just be missing. (...)
(...) with some plugs and sockets left unused for the lower models. The same applies here. (...)
I don't think so (regarding the "may just be missing") - or respectively in this case rather the opposite, one could say (regarding the "left unused for the lower models").
Shall mean., while I agree, that this compartment is intended for a record detection sensor, I'd deem it likely, that this sensor is only required for models, that do not sport a track detection (and arm position) sensor, as the latter would make the former superfluous.
Greetings from Munich!
Manfred / lini
As others have said, that cutout is for the mechanical size detector used on cheaper models.
The SL-J2 obviously shares its platter with these but doesn’t need the size selector as it does this electronically.
SL-J110R platter picture showing the gadgetry below. It’s not exactly the same platter but the concept is similar.
