Technics sl-p150 CD Deck Upgrade
Zekeman
AK Subscriber
Aside from normal cap replacement, is there any way I can upgrade these (I own two of them)? ...opamp? etc?
Features :
-:®:- 1988 model cd player in black
-:®:- Digital / Analogue converter : 18-bit 4 x oversampled D/A decoder
-:®:- Signal / Noise : 96dB at 0.006% THD
-:®:- Frequency response : 2Hz - 20kHz +/- 0.5dB
-:®:- Output voltage : 2V at 0dB -:®:- Outputs : RCA phono x 2 stereo
-:®:- 20 programmable selections
-:®:- Remote control : no
-:®:- Dimensions [W x H x D ]: 428 x 75 x 260mm -:®:- Weight : 3.1kg
Thanks.
This was manufactured before the advent of burned discs. Also, it was made while Matsushita (Panasonic) was still trying to come up with an economical chip set to use for the servos and signal processing.
Other than beefing up the power supply, most of the possible enhancements should lie in the D/A converter and in the filtering network which follows this.
Fred
