SuperMaryo
Hi - I got a Technics SL-P770 CD Player from ebay "powers on otherwise untested" which of course meant it wasn't working. So, it does power on an all the display lights come on as they are supposed to. It will power on and load a disc, but it will either not spin, or it will sometimes spin and then slowly come to a stop. I replaced the spindle motor with an identical one, but it has the same problem. I measured the voltage to the spindle (connector with two white wires almost dead center of the board), and it usually starts up around 1.3v and slowly goes to zero. I'm really not sure what to check next. Some research makes it seem as if some of the capacitors could be bad - I found a Japanese YouTube video with a similar issue where he replaced a bunch of capacitors, but he didn't really show which ones he replaced, but it looked like most of the smallish red ones on the bottom half of the board. If anyone could provide any next steps or ideas, I would be really grateful. Thanks in advance!
