I think I might have the same sound too. Sort of like a groaning sound when playing in automatic mode, especially when lifting and setting of the tonearm. Nothing significant but I just thought it gets old with age. I read somewhere that the dampening grease on the lift either got old or drying out. I do have dampening grease which I use for cassette deck ‘soft ejects’. The same kind you’d use for dampening camera lens zooming. Now I haven’t got that far yet to disassembling the tonearm for such task.Mine had a problem with the tone arm rest, it would not go down so i removed the bottom cover and applied a couple of drops of light oil to the tone arm rest and worked the rod/shaft up and down about 20X and that did the trick i also replaced ALL the caps while i was in there and cleaned the old grease and applied new lithium grease.
The only issue i have not been able to resolve is that when i press play there is a rumble Prrrrt sound coming from the tone arm base but as soon as the tone arm lifts the sound stops and it plays the record without any problems and all functions work.
I anyone has had this issue before let me know what i should check.
Yes exactly, only at start and when the arm is lifting and moving to the record but once on the record there is no problems it's just anoyingI think I might have the same sound too. Sort of like a groaning sound when playing in automatic mode, especially when lifting and setting of the tonearm. Nothing significant but I just thought it gets old with age. I read somewhere that the dampening grease on the lift either got old or drying out. I do have dampening grease which I use for cassette deck ‘soft ejects’. The same kind you’d use for dampening camera lens zooming. Now I haven’t got that far yet to disassembling the tonearm for such task.
On mine the lift arm was stuck in the up position so i used light oil to get it to move and that worked. I did not see that it has any grease in there.I think I might have the same sound too. Sort of like a groaning sound when playing in automatic mode, especially when lifting and setting of the tonearm. Nothing significant but I just thought it gets old with age. I read somewhere that the dampening grease on the lift either got old or drying out. I do have dampening grease which I use for cassette deck ‘soft ejects’. The same kind you’d use for dampening camera lens zooming. Now I haven’t got that far yet to disassembling the tonearm for such task.
@mrteasdale,Your "Prrrrt" sound is more than likely the worm drive and gears objecting or maybe a bit worn. I'd download the service manual and set about dismantling, lubricating and resetting to the correct start positions detailed in the manual. Probably not related to your "Prrrrt" but it's worth following all the recalibration measures also outlined if not done so already. Good luck!
I thought the sound was always there, but just didn't notice it until lately. Also had the tonearm stuck up when I press play. I had to manually lift the arm to play and manually put it back when the record is finished playing. It would not go back to its resting position. If I press anything it'll get stuck right back up stiff. I corrected the problems by replacing all the caps, since then it's been working like how it should. I'll just leave that slight groaning sound alone for now.Yes exactly, only at start and when the arm is lifting and moving to the record but once on the record there is no problems it's just anoying
sounds like gears not meshing properly..For now i am going to use it as is, i don't want to create more problems by removing the tone arm assembly. Are you going to do that?
Cool that you had the problem resolved! did you also replaced the grease? and did you lubricate the tone arm rest shaft/rod?I thought the sound was always there, but just didn't notice it until lately. Also had the tonearm stuck up when I press play. I had to manually lift the arm to play and manually put it back when the record is finished playing. It would not go back to its resting position. If I press anything it'll get stuck right back up stiff. I corrected the problems by replacing all the caps, since then it's been working like how it should. I'll just leave that slight groaning sound alone for now.
No, I only replaced 13 capacitors including the big axial one.Cool that you had the problem resolved! did you also replaced the grease? and did you lubricate the tone arm rest shaft/rod?
it would be a good idea to do that also.
When i replaced the caps i still had the tone arm rest problem it would not come down but once i lubricated it and worked the shaft it started coming down like it is supposed to.
Cheers
Well as long as it is working properly that is all that counts.No, I only replaced 13 capacitors including the big axial one.
