Technics SL-QX200 vs Technics SL-D2
bigtigmn
So I've been using an SL-QX200 with a P228. I had planned on putting a P-mount M92e cart with a M97xe stylus in soon.
I just purchased a SL-D2 and I only plan to keep one. At first glance the SL-D2 looks more substantial and has a normal mount which is handy. I just installed a M97xe
I'm very curious about some thoughts about the differences between the two.
I'm about the do some listening tests and will post some thoughts on those as well.
I'd be interested to know how this all turns out. I have an SL-D2, and it is a very respectable table. It has a curved arm and is a pretty straightforward semi-auto deck. As for the other, I don't have experience but I know that I like Quartz-locked for sound, but am not a huge fan of straight tonearms. These are personal preferences, of course, but sharing those is what a forum like this is all about.
Anyway, I would be a bit bias towards the SL-D2 just because I'm familiar with it and it takes standard cartridges instead of P-mounts, which gives you a bit more flexibility.
So far here are the results after listening for about a half hour. I listened mostly to one song for about 20 minutes working to discern differences. It's an album I recorded in my studio so I already had a good idea of some of it's intricacies from the studio.
Isolation - The SL-QX200 seems to have quite a bit more microphonic tendencies. I don't know the vinyl term for it but when placing both tables on the workbench that the Advents were on both tables received a sort of microphonic feedback mostly from low frequencies but also highs. Although they were both suspect the SL-QX200 was a little worse. Moving to secure location helped this.
Frequency Range - The SL-QX200 seems to have a lower extension maybe in the range of 5-7hz. It's fairly noticeable as it brought subharmoic instruments back to focus that I remember being int he original recordings. These were not nearly as present on the SL-D2. Also I heard the effect of better stereo imaging on the SL-QX200. A guitar present on the right of the track seemed to have more presence on the right. My assumption is that is simply due to the back the SL-QX200 seemed to have a clearer or more present high end.
Dynamics/Depth of Field - The SL-QX200 seemed to win here as well, changes in vs to chorus etc, seemed to jump out more, and although it was slight I could catch revery tails a little better on the SL-QX200.
All of these differences were very minute mind you. I really had to look for them.
Still curious other folks thoughts though about the tech side.
