merrylander
AK Member
After putting the RB300 arm on my Planar 2, I bought the SL1600 mainly so that I could swap about cartridges. After cleaning it up I set about mounting a cartridge and was really shaken when I found that I could barely get a balance, it was as if all the carts had suddenly lost half their weight. I recalled that when I had repaired a similar TT for a coworker it had an AT cart of some description and had been easy to setup. Examination of the end of the arm revealed the small screw on bit that you see in the photo. Amazing just how heavy that little piece is. Once removed balancing the carts became a breeze.
I downloaded a SL1200 owners manual from Technics and found that their TTs come with extra weights for both ends of the arm. The sl1200 arm looks like the same model as the SL1600.
Rob
Rob
