pete_mac
Something abnormal is going on here at Casa Del Mac - I'm suddenly over-run by Technics turntables! First, my new SL-120, and now a SP-10 MkII that an Australian audio nutter asked me to inspect, caress and rejuvenate where possible.
The legendary SP-10 speakers for itself, so there's no need for me to copy and paste the usual guff here. However, I will certainly say that it is built like a TANK.
This particular unit is an ex-ABC turntable, and the ABC sticker is still affixed to the casing of the power supply. The power supply was refurbished at some stage in the past, with high quality caps used throughout. The neon lamp is dead though, and this will most likely be replaced with a suitable LED conversion.
[/URL][/IMG]
The chassis has experienced some corrosion over the entire surface, and has a mottled 'salt and pepper' appearance. It is quite smooth to the touch though, so it may have been cleaned, sanded and polished at some stage. It would be a prime candidate for refinshing in future. I foresee a factory silver or satin/gloss black finish on the horizon (although I could be very wrong!)
First things first... let's unbutton her!
Platter removed:
Cast alloy baseplate removed (some minor marks here, but you won't see it once it is mounted in a plinth)
Mmmm... very clean and shiny! All of the PCBs are attached via one main PCB with slotted arrangements, much like a PC motherboard.
Got ICs??? Yup!!
Now, being a Technics/Panasonic/Matsushita turntable, the caps throughout are Matsushita/Panasonic. So, I've endeavoured to use Panasonic caps during the refurb where possible.
First board removed (including the quartz locking circuitry)
Old caps:
New caps:
Second board removed - this one features regulators on a aluminium heatsink which attaches to the chassis. To access some screws, the power supply connection point must be removed:
Old caps at various angles:
Now... remember how I mentioned wanting to use Panasonic caps only? Well... I've finally ran out of my supply of 1uf Panasonic FC caps, and Panasonic 1uf caps are getting hard to find at short notice! I have some nice Nichicons coming tomorrow, so these will have to do. They're Japanese, so the underlying heritage of the turntable will be largely unaffected
Platter removed:
Got ICs??? Yup!!
Old caps:
New caps:
