Ian Ramphal
So in 1977 I was gifted a ST-S7 tuner. Worked perfectly until 2008 when the display panel started to fade away. That's 30 years of daily use. Opened it up and looked inside and threw it away as I had no clue what I was looking at.
Now, 18 years later I wanted another and it has the same issue. Google search revealed an age related problem with dimming display resulting from the "voltage pump" that raises the display voltage to -32V (or could be +32V) for the display to light up.
I have the original ST-S7 Service manual which does not indicate the voltages/pins to check, plus an online download schematic.
Google tells me it's the voltage pump, driven by a couple of Caps and Diodes (that tend to fail) to raise and supply the +/-32V to for the FL Drive to power the display. But, I'm a novice.
Can anyone advise me as to what pins, etc. I should be probing, or what caps I should be replacing?
I assume that the area in question is whatever is powering the "FL Drive".
HELP PLEASE!
HELP PLEASE!
