Hi all,
I bought a Technics SU-8088, which is working, although one of the circuit board is broken (I assume it happened due to shaking, proper of international transportation).
As seen in attached pictures, the circuit board of the main filler caps is broken nearby two of the screws, which I assume also support it’s weight. Apparently, it is not affecting any circuit.
Is the weight of the caps supported only by those screws, and is the rest of the board in stress?
What do you recommend I should do? Leave it has is, and enjoy until something worse happens?
Is there any possible fix, for instance glueing the circuit board? will I need another circuit board (because the rest of the amp looks good), and if so, is it replaceable with other models (for instance, the SU-8080)?
