perokl
Hello all,
I'm here now, and im sure the vast knowledge held on this site, is going to help me.
After successful rebuilding my SU 8077 and SU 8088 now ist time to do a rebuild on my old dusty SU 8099.
I made a list for the Capacitors (some are leaky) to replace:
I'm also planning to replace the trimmers for Bias, all Relays and take out and clean all switches .
On the SU8077 I also changed the double transistors 2SA798/SC2291 with SA992/SC1845 and on the SU8088 the SA995/SC2291 with the same SA992/SC1845 as recommended here:
http://audiokarma.org/forums/index.php?threads/technics-su-8077-rebuild.756525/page-3#post-10357951
On the SU8099 main amp. board I found the SC 2291 and SC 1583 double transistors,
Should I also change these whit the SC1845?
I also found double transistors SA995/SC2291on the MC-EQ preamp board
should I change these too? Whit SA992/SC1845 or something else, or should I keep the old ones?
Does anyone have any suggestions on what should be done else,which parts should be also swapped out,
that the amp last for another 40 years?
