Janochytron
Hi,
I am new here and also to the world of amps. Only recently got a JVC ja s11 by dumb luck and love the sound it produces. Obviously I started to look at other amps and delas on ebay and got few more. I am interested in learning audio repair, so I got a faulty Technics SU-V1X for few bucks.
It has no sound out just loud hum and there is DC Voltage on speaker terminals. I have measured the pins on the IC - SVI 2003 A, new class A chip. The pins 3 and 14 should have 0 V, but have 33-34. Other supposedly low voltage outputs are all high, the high ones are slightly lower than in the schematic.
I can post measurements and correct voltages.
Similar on the other IC - AN7062 voltage amp.
Anyway, my question is, how can I make sure the ICs is faulty, what other measurements should I take?
When I opened the amp (very dirty, nicotin film all over the inside) I noticed a burnt circle on the upper cover (from inside) Under it I can see evidence of some burn around D505, 506,507,508 and resistors R501,502.
The voltages before and after look ok, all the diodes tested 0.943 on diode test (one way).
Any help would be greatly appreciated.
Pictures attached
Pictures attached
