Hello all!
I have a Technics SU-V505 and I've had an intermittent problem for quite a while that seems to be getting worse.
It started going quiet with one channel. This was resolved by turning the input selector around and that usually did the trick. Sometimes turning the speakers off and on again would work. Worst case scenario - power off and on again. It was pretty rare so I didn't worry too much.
Now it's becoming a real drag and often isn't fixed by any of those things.
I used contact cleaner in the pots and that seemed to do the job for a bit, but now it's back and the cleaner isn't fixing anything.
Looking more closely I noticed that the 'bias' lamps don't come on when the amp is started up anymore. I read somewhere that these bulbs operating is critical to the amp itself working effectively... could this be the problem? Two bulbs are off : the bias lamp and the 'computer drive' lamp.
The guy I got this from told me that the lamps had been changed recently, if so I wonder if there is an underlying problem that is causing them to blow...
I also read in this thread (https://audiokarma.org/forums/index.php?threads/technics-su-v505-problem.298040/) someone had a similar problem solved by resoldering the speaker relay.
Perhaps resoldering the relay will fix the issue? Could the bulb even be not lighting up because the relay solder is bad?
Any help much appreciated! (inc. any pictures to point out where the speaker relay is!!)
