Technics SU-V8X
Synchro-bias
New ClassA
:music: hello
I want to share, one of my amps. It has a beautiful clear sound, bright, bass is nice.
Technics SU- V8X 1983 - 1985
  • Computer Drive New Class A
  • Syncro Bias
  • 4 x 8200uf low ESR (Equivalent Series Resistance) electrolytic capacitors
  • Power Transformer with OFC wire in a case of heavy magnetic sheild of special resin to reduce vibration
  • High Quality Source Straight DC
    Specs:
  • Power Output: 150 w (6ohm) 0.005 %
    120 w (8ohm) 0.003 %
  • Total Harmonic Distortion: 0.002% (20Hz ~ 20Khz, rated output -3dB)
  • Power bandwidth: 5Hz ~ 100kHz (THD, 0.002%, 8ohm)
  • Dimensions: 430w 141.6h 380d
    Weight: 12.8 kg
    Power: 670w
http://translate.google.com.au/translate?hl=en&sl=ja&u=http://www.niji.or.jp/home/k-nisi/su-v8x.html&ei=4PQNSr3_MsiHkAWQvIitBA&sa=X&oi=translate&resnum=6&ct=result&prev=/search%3Fq%3D%2522Technics%2BSU-V8X%2522%26hl%3Den%26safe%3Doff%26sa%3DG
