elnaldo
Lunatic Member
* suspect of everything you did and you don't trust 100%, even pulling too hard from a wire could damage a connection.
If you just desoldered those transistors, the problem should be there. But if you shorted something else while testing the amp, it's hard to say from here. Check the PCB traces and check continuity from your new installed parts to the next point on the PCB.
Make a mental list of things you don't trust and you are not telling us, the problem is usually there.
Try to keep the unit factory original, without replacing more parts so you don't introduce more variables to the problem.
