Hello! I recently bought SL-QX-300 turntable. Only when at home i unpacked the unit i saw that one of the hinges has split in half (mplastic part). Dusk cover and small plastic holders on it are fine. I have many different hinges but non of them would fit. I found this: https://www.terapeak.com/worth/tech...-dust-cover-hinges-repair-parts/301723720502/ the hinge is the same except my model have also small legs on the metal part otpf the hinge unit. Maybe someone knows if its possible to split metal housing from the plastic part, since i only need plastic part is for the fix.
