K
kitsap2
Guest
Not much going on here, I'd like to bring up a topic that has been discussed, but not for awhile. Feet. Foots. Specifically, Herbie's gliders. My listening space is a concrete slab with vinyl plank flooring on top. I have both the studs and the spikes Tekton sends out. I don't like the spikes, every now and again I need to move the speakers and it's a royal PIA with spikes. So I use the studs on my Pens. I found using hockey pucks und the studs sounds better than the studs right on the floor. Mostly on the lower end and the "floor" doesn't vibrate with the pucks. One drawback is the speakers are not rock solid planted, there is a bit of jiggle with the pucks. And sliding pucks on the floor is a no go, maybe even worse than the spikes. So, anyone using Herbie's gliders or giant gliders? A set of gliders is under 150 and the giants are over 300. At 90 some lbs and tall, it seems to me the giants are a better option. A real long shot if anyone has used both...you know, the ol' buy the cheaper version, lose 50% and end up buying the bigger version routine. And as for GAIA...too costly for me.
Do you think you could get away with, Magicsliders, or similar, cheap alternatives? I've used them for years on heavy furniture(solid pine entertainment unit) which sits on pergo type flooring. A set of Magicsliders, and their competitors mostly all fall under $20. Just a thought.
