Telefunken Record Label?
Yes, the fusion was mutual between Telefunken and UK Decca. Their recordings as a rule are superb, especially their superb Das Alte Werk baroque music line. Their classical recordings and pop recordings are of high quality, their pressings are superb, flat, quiet, and substantial weight.
TCS 18018 sounds like it is an American mastering and pressing of a Telefunken issue originating in Germany.
Telefunken in the USA, during the late 1950s through the 1960s, was issued by the Decca Record Co. (UK) whose American subsidiary was better known as London Records. While most London classical issues were imports from the UK of superlative quality, with London labeling and London numbers (at the time, Decca USA was a separate company), most other London products such as their pop records, the budget classical Richmond line and the Telefunkens, were pressed in the USA, and those pressings were on inferior vinyl, often tending to be noisy. Inside the cardboard jacket, they came in paper sleeves which seemed to have been resurrected from a former life as flour sacks.
I have owned from brand new (that's longer ago than I want to think about), Telefunken TCS 18003, the Beethoven Symphony No. 3, the Hamburg State Philharmonic conducted by Joseph Keilberth. It is a fine performance but the constant surface noise was so annoying that it was difficult to listen to it all the way through. After many, many years of playing it with the latest audiophile super cartridges that would track at a minuscule weight, I finally had at it with a Stanton 500, with a genuine Stanton spherical stylus in white, marked only "DJ." It was specified at 2-5 grams. I washed the record, then gave it all five grams (with a 0.7 mil spherical there is no fear of record wear) and the surface noise was lessened by about 80%; meanwhile the amount of junk that the stylus dug up was astounding. I repeated the washing and played the second side, the same way with the same result. A second playthrough of the whole record dug out even more junk. Now, finally, it plays quietly.
Thanks for all that information! Gives me hope that I might find a way to tame this beast. I have recorded it to FLAC however, and will soon give it a try with Audacity and see if I can clean it up some that way.
I have alway used Stanton cartridges (681-EEE's)and I have run into the same thing you did. It was like the stylist was out in a farmers field plowing for the next crop, even after cleaning it with an ultra-soft tooth brush, dishwashing soap with plenty of water; Residue from smoking?
I managed to come across the entire set of the Bach Cantatas on Das Alte Werk almost 20 years ago during the days when vinyl was dying an excruciating death and everyone was climbing over each other to divest themselves of the loathsome LP records. I am a huge fan of the Cantatas and a huge fan of Telefunken recordings. On a well sorted system they exhibit qualities which elevate them into the highest echelon of analogue recording.
This recording quality can be further utilised to ascertain and quantify sonically improvements and backward steps in system fine tuning. Forget the oscilloscopes. Get out the Cantatas. That's the left-brain use. Once the fine tuning has been optimised, then right-brain wallow in the magnificence of what Bach wrought and Telefunken, the conductor and the musicians bring to life.
Just wonderful.
A pearl from the Das Alte Werk Cantata set is BVW 11. :thmbsp:
I came across a thrift store LP recently, cleaned it up, and I'm playing it now. Unfortunately, there is a quite a bit of crackle; due, I suppose to the way it was stored, sans liner. But I may be able to rescue it in Audacity, we'll see.
It's "Waltzes of Johann Strauss," Joseph Keilberth conducting the Bamberg Symphony Orchestra, Telefunken TCS 18018. I'm not familiar with Telefunken as a record label. This is a stereo release; although I'm not hearing a lot of channel separation here. Any thoughts on this label in terms of quality, or this particular release? I know there are a few classical fans here on AK who know the older releases.
I have a modest vinyl collection by a serious collector's standards. But if you wanna know what a record sounded like when it was new, buy a Spin Clean mark ii. Seriously. I have 40-, 50- and 60-year old records that sound beautiful.
