Ten Years On AK
musichal
poet emeritus
I just noticed that yesterday was my tenth anniversary as an AK member. I've learned a lot here, casting away some misconceptions, preconceptions and deceptions, and there is always a ton more to learn. The main impact of hanging with you guys has been the evolution of my main system, which continues, so maybe I'm running with the right crowd.
Or maybe the wrong one?
The only component I have left from ten years ago is a Lexicon DC-1 which has been relegated to switching duty for old composite (RCA) pre-HDMI video outputs, but it rarely gets used anymore.
How much, or how little has your system changed since joining?
Congratulations! Here’s hoping for 10 more.
My system has changed many times since joining, so I set out to work on my analog getting it sounding the way I like it and that has been accomplished with the Mighty Modded MarcMorin ARXA Musical Fidelity NuVista setup . So then it was time to work on the digital side which needed allot of work because it always sounded hard and edgy to me . After adding the MF NuVista and TriVista 21 Dac along with allot of other details my digital is so good that sometimes it’s hard to listen to vinyl for the convenience factor (I’ll never leave vinyl) but the sound is so detailed and refined with the slightest bit of warmth from the Tube pre in both the amp and Dac , my digital is exactly where I want it .
I have reconsidered looking for a set of Vandersteen Quatros for the time being and keep the 2ce Signature ii’s because it has brought a new dimension to my whole system . So yeah my setup has done a 180 since I have joined AK and I have the members here to thank for all the help that was/is given and of course Mister Pig for his guidance and great gear he has passed along for me to enjoy.
Audiofreak71
Congratulations on 10 years here! Your contributions are greatly valued.
Since I've been here, I've added 3 turntables, a few sets of speakers, and a new integrated amp. Learned what to look for, and what to avoid, and my preferences and peculiarities may not necessarily be just my own.....
When I climbed aboard in 2006, everything @ "my system" was analogue. More than 12 years later it is entirely digital. I still have all of the analogue (audio) gear, but I don't use it. I still do use my analogue (and, all-tube powered) geetar amplification, nothing digital or even SS in those rigs. But for daily "audio" activities, it's computer > external DAC > bluetooth-based, AC-powered speakers, of which I have several I can run, simultaneously, in different parts of the house. Talk about "surround sound", it's more like "surrounded by sound" here.
Except for the HT in the living room (which sees no use)
Everything has changed.:idea:
I'd guess there are some stray interconnects here
Hers's to 10 more Hal. :beerchug:
as for the system....nothing from 10 years is left in use. Still have some of the old components but none are in use at the moment. My Altec's are about that old and they're in use in the garage. But that's about it.
and fwiw I hit the 10 year mark back in August. Time flies......
To quote the great Graucho
" "PLEASE ACCEPT MY RESIGNATION. I DON'T WANT TO BELONG TO ANY CLUB THAT WILL ACCEPT PEOPLE LIKE ME AS A MEMBER"."
Fortunately they only let so many folks such as myself in, otherwise I would have to resign. It's good to see you around this long. I think about the folks we have lost over the years, and its a bit sobering to think of the mainstays that no longer call here home. Their contributions make AK better, as does yours. So stay a bit more OK?
And let us not forget Christine, your partner in crime. She deserves mention also.
Cheers
Mister Pig
A lot of changes since March of 2005, and in many ways my current setup can be viewed as markedly inferior to what I had then, but it seems to let me love music just as much. In fact, I spend more time listening to music now than at any time I can remember, and reviewer Art Dudley once opined that for a system change to be an upgrade, it should result in spending more time with your music. In that regard, maybe this is the best I've had.
In 2005, I had just replaced my Linn LK1 preamp (bought around 1987 or '88) with an Audio by Van Alstine OmegaStar preamp, the LK1 having developed control board faults for which parts and service were no longer available. At that time, my system consisted of a 1993 Cirkus model LP12 with Basik power supply and Ittok LVIII/2 tone arm (which replaced my first LP12 purchased in 1985). The power amp was Linn's LK2, though I had the LK280 upgrade kit installed at some point. Speakers were Linn Saras, bought in 1988 if I recall correctly (I had purchased that all-Linn system in stages over the course of a few years, the Saras being the last piece).
In 2008, my Sara speakers had a driver failure and were replaced with Vandersteen 1C's. The LK2 power amp never broke down, but I replaced it with an Audio by Van Alstine Insight 240 that same year, along with buying a Well Tempered Record Player, a Grado phono stage, and Grado cartridge. This was an experiment, prompted by President Bush's plea for stimulus spending on American-made products, to assemble a system that would do imaging and soundstaging better than my all-Linn system could do. The new system did those things very well; for example, in Mozart's Notturno for 4 Orchestras I could hear the placement and depth of the echoing orchestras relative to the main orchestra in a way that was never apparent before.
Within a few years, however, I found myself preferring to play the Linn (not from a sonic standpoint, but I loved having a cueing lever, a much less fiddly procedure for changing cartridges, and not having an exposed belt around the platter), so I sold the WTRP, and the Vandersteens found themselves replaced by a pair of Bose 301's, which had a much wider sweet spot for listening, and its strengths in timing, rhythm, and dynamics were more important to me than the Vandersteen's strengths in precise imaging, depth of soundstage, detail resolution, and frequency extension.
I've moved twice since then, and the system has undergone two additional changes. A single Bose 201 has replaced the pair of 301's (I find the smaller speaker and playing in mono mode better suited to my smaller listening space), and a Rega RP3 has replaced my Linn LP12. The LP12 was getting along in years, and my dealer said that within a few years I would likely be needing to replace the main bearing, motor, and power supply. Instead, I opted to have the technician tune up the LP12 with new suspension parts and cartridge and put it on the market, eventually using the proceeds to buy the Rega. In audition, I wasn't overwhelmed by the RP3's predecessor, the P3-24, but the RP3 was a big step forward in terms of pace, rhythm and dynamics; as one review put it, the RP3 is "contagiously musical" with "an uncanny ability to get to the heart of the music." As mentioned earlier, I'm playing and enjoying music now more than ever, and would be very content to live out my years with this level of sound quality.
When I started here I had only 1 set of speakers (Alison CD7) 1 receiver(inexpensive H-K) a direct drive Technics TT and a mid 80's Toshiba CD player.
Since than my 1 system has blossomed into 2 very nice systems with an "adequate" number of spares. I have always enjoyed my stay here in AK land
Congrats...worth celebrating at least as much as post count.
It's not only the knowledge here and how it improves your system, but it's also the people that make AK a great place. I include you in that musichal. :thumbsup:
Congratulations on ten years! Hope you have many more here. I really enjoy what you bring to the AK family.
Since joining in August 2007, my systems have changed very little. A few new carts, some better wire, a pre-preamp, but I’m decidedly old school and too old to mend my ways.
Congratulations on 10 years. Coming up on 15 for me. There have been a lot of people pass through our halls.
Shrinkboy, April/03, is ID# 728
I'm Dec/03, ID# 1605
musichal, Nov/08, ID# 51876
MAoro337, our newest member, as of this post, ID# 293547 (Yep, nearly 300k)
When we started, after the initial burst of speed, the growth rate was a bit slow, but we've made up for lost time. The lifetime average is better than 53 new registrations per day. For over 15 years.
Coming up on 9 years, when I started I had a decent home theater and an SL-1700Mk2 I bought in the early 80s that had been sitting 20 years. AK got me started on re-entering the vinyl world and put me in touch with the local miscreants. I now have 900 records and the rig in my signature. Couldn't be happier with the hobby and friends!
