PaulOliver
Hi all,
I'm working on a Teppaz Présence portable record player/amplifier and I'm stuck with voltages that are too high everywhere. I've been troubleshooting this on a French forum and I'm hoping fresh eyes might help.
THE CIRCUIT
- EZ80 rectifier → EL84 output stage
- Power transformer secondary: 2 × 350V AC
- Mains input confirmed at 230V, 110/220V selector correctly set (I disconnected the 110/130V leads and wired 0-220V directly to the primary)
MEASURED VS. EXPECTED VOLTAGES
- EZ80 output (1st filter cap): 370V DC (expected ~300V)
- EL84 anode: 360V (expected ~280V)
- EL84 screen grid G2, after 20kΩ: 240V (expected ~220V)
- EL84 cathode: 6.86V (expected ~5.2V)
- EZ80 heater: 7.5V (expected 6.3V)
WHAT I'VE DONE SO FAR
1. Verified mains voltage and 110/220V selector wiring — correct
2. Checked for retrofitted 1N4007 diodes near EZ80 socket — none found
3. Measured cathode resistor (desoldered one leg): 166Ω (spec ~150Ω, only ~4% drift — not the culprit)
4. Replaced the 50µF cathode bypass capacitor with a new 47µF/50V — no change
5. Noticed the main filter cap is 50µF but the schematic calls for 32µF — ordered correct 33µF and 10µF replacements
6. Calculated cathode current: 6.86V / 166Ω ≈ 41 mA — should be closer to 55–56 mA. The EL84 appears to be drawing about 15 mA too little
DIAGNOSIS SO FAR
The EZ80 has relatively high internal resistance. Without sufficient load current, its output voltage rises — which explains why everything reads high. The key question: why isn't the EL84 drawing enough current?
Possible causes discussed:
- Leaky cathode bypass cap weakening the tube (replaced it — no change)
- Oversized filter cap (50µF vs 32µF spec) contributing to higher voltages
- The EL84 itself could be weak/fatigued
Thanks in advance!
THE CIRCUIT
DIAGNOSIS SO FAR
Thanks in advance!
