Water injection is an accepted practice to keep combustion temps down (detonation) but as far as burning it, nothing short of actual hydrogen is currently used that I am aware of. Hydrogen is combustible and oxygen is an accelerant so if the atoms can be separated Katie bar the door.Do I remember correctly that some of the WWII bombers had water injection?
The people who said this is impossible are right.
I would have never thought that any ak member
would think that water could work
as a fuel
I have been schooled
We had a waste oil / water drip heater at my former place of work.I'm thinking an engine could run on a mix of fuel and water (hydrogen and oxygen). I say this because 40 years ago we heated our shop with mostly water, it was in a waste oil heater that used transmission fluid, motor oil, varsol, or anything we could get a fire started with. We got the fire in the burner good and hot, and started a water drip, which increased the size of the fire by about a factor of 5. When the drip was too fast, it would extinguish the flame, but the flame would get larger and larger the more water we supplied, until it quenched it.
I've been told many times this was impossible, some by teachers and "science" experts, but it works.
The engine would need to have a very lean fuel mixture, then a precise high pressure "fogger" nozzle to inject water into the cylinder. It would create an extremely hot combustion temperature, so the water would have to be used to cool it immediately after it fires.
I'm no rocket scientist but maybe someone else could perfect it.
Oh and turbochargers work well but need fuel to make the juice.
Just for the record, the pursuit was called off for safety reasons, per the department's statement...
Remember when Tesla was planning the battery exchange stations. You would park above a system of some sorts and it would unbolt the battery and slip in a freshly charged one. Would be done in minutes. Was dropped for the super-charger stations. Would have been neat if they perfected it.
I can see it now, the NASCAR BATTERY CUP SERIES. One pit stop for a fresh battery pack per race. One plus would be the noise, or rather the lack of it. You could locate speedways close to or inside most metropolitan areas.
If something is turning like the wheels, you could make it recharge the battery's![]()
Yet there is already Formula E racing - WAAAAAAY ahead of NASCAR
(Conceived in 2011, begun in 2014 ...)
https://www.fiaformulae.com/
That would be the elusive perpetual motion machine. Absent friction, it would work.
As for the water "burning" thing, whats more likely is the steam from the water drip onto the hot burner was causing some of the fuel to atomize which would make it burn faster. Also possible it was adding some cooling to the burner arrangement so it increased the fuel flow or air density or something.
