nashvillebill
Ahh, in retrospect, I think i can see why some people get confused....Some people think amps PUSH power out, like somebody pushing a boulder up a hill...the heavier a boulder, the harder one has to push, right??
But this is incorrect. Amps don't "push"--they merely provide a voltage potential...it's easier to envision that the load PULLS. The lower the resistance, the more the load "pulls".
In reality the load isn't actually "sucking". The amp is a voltage potential and electrons are seeking to flow from the low side of the potential to the high side (if you must ask, centuries ago they arbitrarily chose "positive" and "negative" before they knew about electrons.) If there's a lot of resistance--a speaker with lots of ohms--few electrons can flow. Hence, little current flows. If there's little resistance, lots of electrons flow, hence lots of current. If the amp cannot supply the amount of current that should be flowing, the amp "clips" and bad things can happen.
