Plimpington2
I do not have a signal generator, so I gather my testing of an output transformer is not ideal. That being said, I’ve done some basic things to check for shorts and continuity, and have a question that i don’t quite understand:
On the primary, there is continuity between each leg and the center tap (my continuity meter gives a sustained beep). However, the R between one of the legs and the center tap is 104 Ohms and on the other it is 126 Ohms. Is it strictly normal to see this vary between these two readings? Does this mean the center tap isn’t *quite* centered?
Moreover, I cannot get a resistance reading between the two legs of the primary. My multi tester just flashes as if *trying* to find a reading, but never does. Also, on the continuity tester setting, it beeps once and then stops.
I note these findings hold for both OT’s I am testing (these happen to be a set of monoblocks. I would doubt they are both bad.
Thanks
Justin
Thanks
Justin
