Great thread
@Grbluen!! It provided useful information.
I'm not worried about the uni-pivot on my VPI because the arm is basically balancing on a very sharp spike, so how much friction can there be. I guess that's the point (pun intended
) of an uni-pivot but I've been very curious about traditional bearings and definitely wondered about the condition of the 40 year old stock bearings on my Sansui 838.
I had some time to kill today so first I tried the the KAB method that
@mackat linked and it passed with no problem. It also easily passed the breath test
@ConradH mentioned. Then I did the paper test
@The Slider suggested and to my surprise it also worked like a charm. A tiny piece of paper actually did make the tonearm drop.
Then I decided to step it up a notch. I wanted to see if something that definitely weighed on the very low side of the single digit milligram range would move the arm. My scale only goes into the hundredths so I had to improvise a bit. I weighed a lead pencil insert and came up with a weight of .08 gr. So it follows that 1/10th of the length of that insert would weigh ~8 mg so I broke off a tiny piece that was
much less that 1/10th (probably closer to 1/20th or ~4 mg). As expected when I placed it on the scale there was no reading at all. But when I placed it on the floating tonearm it dropped!. Not bad for a stock tonearm bearing that is at least 40 years old!
By all accounts these arms/tables were made for Sansui by Micro-Seiki.
Gotta hand it to Micro-Seiki, I'm impressed!
For scale:
