Thanks Kamakiri
MikE
Color Me Gone
Look what Tim sent me! A vintage Mullard gz32 [5v4] rectifier! :banana:The date code [R71 B8F] reveals this tube to be gz32 batch code 1, manufactured in the Blackburn factory 1958, June. While the number "8" refers to the year of manufacture, we know this was 1958 and not 1968 because until 1965 the factory/date code (second code line) was three digit: B2A = date code Mullard Blackburn 1962 - January. After 1965 the code was four digit: R3I4 = date code 1973 - September - fourth week.
You can see the Mullard "Old Shield" label is in great shape [important for collectors] as is the tube itself. As Tim inquired in his "Look what I didn't need" post, the Mullard name is well respected and much sought after, as much for sonics as reputation/name appeal. I own a Mullard blk "Fat Base" and Amperex "Metal Base" 5ar4. Both excellant and highly prized. Unfortunately, I'm unable to use them much seeing that I always have 45s, not 2a3s, in my amp. But the gz32 is a 5v4 and suitable for 45 operation in my amp. And while not a perfect match - gz34 [5ar4] has a max current draw of 750 mA. The gz32 is 525 mA - unless you run the amp extra hot, the gz32 should accomodate. I've used JAN CRC RCA 5v4 w/o problems but my amp is over-built and can tolorate anomolies other amps can't. Some people may disagree.
So how does it sound? In a word, excellant. I've had a fling with Mullards before but not in the last 3-4 years. So I wasn't sure what I'd think of this tube. Surprizingly when I pulled my Raytheon 5u4gb I was taken back by the difference. The Mullard was more open and free sounding. It didn't pocess the density of the Raytheon, it was leaner sounding without sounding lean. There was much better seperation of instruments and the right mix of detail and smoothness. These are my initial impressions [always suspect] so I'll continue to listen and do A/B/A comparisions. Outside of those qualities mentioned the overriding characther is that of a effortlessness to the presenatation, one that is quite beguiling.
Thanks again Tim. I thought I was just getting a collectable. Instead I may have found a new reference. Oh, boy... might have to score me a few more of these! :yes: MikE
Glad you like!
When I saw your response to the thread, I knew that the best thing I could do with it is send it to someone who'd truly appreciate it.
Merry Christmas :)
First Mullard I've ever seen that was that large......just goes to show you that you never know what you'll find at a thrift store :)
