The "$250" Amp? - 6LU8 Compactron SE, UL
As far as does Edcor have a suitable power tranny, Yes..(2)
This one if using a 5v rectifier like the 5V4G
http://www.edcorusa.com/Products/ShowProduct.aspx?ID=585
This one for using the 6.3v rectifers like the 6BY5G, EZ81 OR it can use the 5V 5V4G.
http://www.edcorusa.com/Products/ShowProduct.aspx?ID=583
Thanks! I see it costs about 40% more than the Antek... although the blue paint is pretty darn cool. :thmbsp:
Other than the color, is there any other advantage over the Antek?
For me personally I see no real advantage using 1 power tranny over another, except $.
(unless of'course you want to try different rectifiers)
(I took some liberties with your BOM post) :)
(used my mod status to hopefully "help out")
With a pretty standard 120v wall voltage you should be able to follow the build just right.
Kegger, could we interest you designing a tube phono preamp to mate with the 6LU8 amp?
For the time being it would have to be a no, I have got a couple preamp projects in
the works an a few more amps before I go to the phono, on the way way way back
burner is the phono stage, but not sure on topology or the tubes being used as yet.
(phono stage I have been running is an EAR 834P I'd modded some time ago)..:music:
When you're ready, I'll be building one. You did fine work on this Compactron design. I am hoping rebuild this amp with a pre in the same enclosure. It can wait. I'll use the pre on my Luxman L-110 until I build a tube pre. (I just got a TT again)
No...I haven't heard a 6DJ8 Pre yet. I have read all that I can find on that Tube, and it seems like a better choice than a 12AX7. I'll hopefully let you Know how it does Sound in a couple of weeks...
Oh wow! Very nice. It'll take me some time to look thru that and understand what's new. Thanks! :thmbsp:
I got my hands on a camera.
I warned you.
This is the completed amp.
The box was made as a temporary housing and the panels were cut with that fine precision device known as a sawsall. :D
Another angle showing the "air hole" I made when misjudging where the power switch would fit.
And if you thought those were ugly, don't scroll any further.
Got wire?
When this gets moved into a nice enclosure, I will have a better grounding situation.
I am seriously tempted to build my crossover amp with a terminal strip like that for ease of modification. I realize that connections loosening over time could be a problem but at least all one needs to "reflow" the joint is a screw driver. ;)
mike
Looks like you intended to put a pilot lamp there... back-ordered... that's the story I'd use! :D
'Temporary' solutions usually end up becoming 'final' results around here... will it sound any different in an exotic wood cabinet? :scratch2: Might be a nice accompaniment for some speakers made with that industrial-strength 3/4" corrugated cardboard. :D
BTW I think I have a towel just like that one! :yes:
Anyway, congratulations! :music:
Very cool Pic's, I love the amp, congrats..:thmbsp:
I don't know how many amps are built, I have built one standard an the paralell version,
I know Squidward has one and has those parts to build a second one where he plans on
doing the detailed build layout, I know of two others over on DIYAUDIO who built one to.
If I had to guess there are at least 7-10 of them I have been told about, maybe others:dunno:
I don't think the TubeLab Guy on DIY counts...He makes the Simple SE...From what I can tell, there's Kegger, Squidward, Goya and Me....AnyOne Else out there with a 6lu8 Amp??
I am not talking about Tubelab and his SE board or his 6LU8 type amp though Sled.
I helped 2 guy's thru building this amp, there people from DIYAUDIO that built This amp. :)
