tubelectron
752 about half of TV7- looks like a no brainer?
For me, yes - again, according to your list.
If you really want to match tubes, only - repeat : only - a real bench test can give you consistent results.
Like me, you can built one for the measurement / matching occasion, using regulated supplies, meters... Well, some equipment you need to achieve this as expected :
The prototype, in a more practical to use form...
The final bench version - still using external supplies and meters, but more quick and easy to use "at a flick of a switch".
- all I and U parameters are adjustable and readable - and these are true voltages like if the tube was operating normally, not pulses.
- direct reading of the true Gm.
- direct reading of grid N°1 leak current.
- qualification of the ringing, the microphonics, by ear and by measurement.
- possibilty of measuring gain or power output of a single tube under audio signals, by adding the required external elements.
It is still awaiting construction... To be honest, I barely need such so precise measurements, so the wooden version in picture 3 is enough, if necessary - at least for the moment !
Again, @sancho22 : if you don't need - or barely need - to go that far in tube qualification, the Hickok 752 / 752a would be the best / easiest all-around tube tester to go - according to your list.
I sold my 752a to a friend who needed a good tube tester, for no other reason that I have my 539C and 600 that covers the functionalities of the 752a, so I could let it go (and I know it's in good hands now !), otherwise I would have kept it.
But it's me, OK ?
T
