merrylander
AK Member
As some of you may know, several Yamaha receivers are 'twins'. By that I mean that the CR-620 and CR-820 use the same chassis and case - AND the same circuit boards. True also of the CR-102 and CR-2020. While preparing a CR-1020 for a fellow AK mamber he acquired a TT with a MC cartridge - bummer, the CR-1020 does not do MC. But the CR-2020 does - aha found a circuit board from a CA-810 with the 5-pin pre-amp chips, found all the other parts, so I installed the MC pre-amp circuitry in the CR-1020. A little creative wiring changes and - Voila!. A CR-1020 that does MM on Phono1 and MC on Phono2. Time to put on Simon and Garfunkels 'Keeping the customer satisfied'.
