AR Accessories - Pesent & Absent
I smashed my finger when I dropped a TV on it last night, so I thought I would do a post while I am out of work waiting to go to the doctor.
My AR Turntable came with most of the original accessories, not bad seeing as it was manufactured in 1969.
Here is the cartridge mounting hardware -
These are all over the web in .pdf form, but this is the original owners manual -
Stylus force pressure gauge. I have heard these are an ABSOLOUTE MUST for this type turntable. Fortunately, these are readily available new if yours did not come with one -
Not sure what this thing does, but I believe it measures either tone arm length or stylus over hang. If you need one, vinylnirvana has one you can print out and use.
Cartridge mounting instructions -
All the accessories that I am aware of that did not come with my turntable are:
1. the 45 adaptor
2. the little bottle of AR oil
3. dust cover
4. turntable mat
I really don't want a dustcover. I am going to get a soft, plastic dustcover to cover both the AR and the receiver it sits on when I finally get it set up.
I plan on making a mat from either a thin foam or cork. Right now I am having troble finding the flat, rolled cork at the "big box" harware stores. Eunomians - Where did you find your cork mat???
I want lubricant. I would like to find an old AR bottle and just fill it up with a suitable replacement oil. What kind of oil do I need to use?
I am sure a 45 adaptor will come up on ePray eventually. I have heard that the record spindle on the AR is slightly larger in diameter than other turntbles, so could this pose a problem with a non-original replacement? I ought to order about 100 of them machined if I could get an original one to go by.
Also, my AR came with some "
WARNINGS".
Again, many thanks in advance for any advice given. AK rules!
herbs
