Congratulations!!
I'm sure you can't wait to have the car home with you both.
Please post some pics of it when there....love to see one with the hard top on too?
Enjoy and be safe....
Truly! I cannot wait to put tags on it and start enjoying the drive!
It current has old Pirelli HP tires, so one of my first task is to go to my friend Paul's shop and get 4 new tires on it!
I just heard back from the shop - they've done all these updates and we are sorting details to get it shipped here next week!
- Rear end fluid had already been done, looked new and wasn't leaking. Replaced bolts and lock washers
- Trans fluid changed, 2 plug gaskets
- Removed lower rad bracket and straightened. JB welded a new pin on the lower radiator because the pin had broken off. Drilled one broken bolt and
replaced with Rivnut. 1 good used radiator bushing. Replaced all bolts.
- Removed center fog lights (our request - for some reason, the car had 4!)
- P/S Belt
- Drained P/S fluid and replaced with ATF and Lucas additive
- Alternator bearing feels fine, no noise.
- Replaced cracked expansion tank small hose
- Radiator cap, topped off coolant
- Tightened luggage rack, replaced 2 missing screws
- Trunk Pistons (the luggage rack adds weight to the trunk lid)
- Reattached broken purple wire for trunk light switch
- HR1 oil and wix filter
- Cleaned and installed hardtop. Put mounting brackets on body
- Lowered choke high idle
- Straightened antenna and tightened base
- Wiper blades
- LED dash bulbs
- Shift bushings
- Braided clutch line and bled
