MyHeresyIsMe
Well-Known Member
Many of your Lux folks may remember that I wrote about a Luxman R-1050 I bought that needed dial lamps. That's not unusual, but what was unusual was my discovery that the owner before me ---or the person who worked on it for him--- used epoxy to install the knobs. Now, why would he do that? The knobs are on split shafts. There's no reason for epoxy to 'weld' on a plastic knob to a three different pot/switch shafts. When I tried to remove the knobs, they wouldn't budge. I contacted the guy I bought it from and he answered my question about the knobs by saying, 'yeh, they are on tight and I couldn't get them off.' He didn't say they were epoxied on.
This saga continues. When I pulled one knob to no avail, I real pulled it HARD. Yes, I pulled the rotary switch's shaft straight through, detroying the two wafers for the Speaker Selector switch. The knob was still in one piece in my plyers, connected to the shaft. I installed another rotary switch. Then I found that two other switches had been epoxied. Why? I think he was nuts. Anyway, I then had to replace two other rotary switches (one was that monster Function switch of "AM/FM/Ph1/Ph2/Aux"....five wafers). While I was in there I saw that this same person had epoxied the dial glass onto the dial.
After hours upon hours of work on this R-1050, everything works again, even after I had to restring the dial cord (a slip of the soldering pencil---my fault). Was all this worth it? Yes. The Luxman R-1050 functions perfectly (I don't know about the Phono for Moving Coil cartridges). The tuner is great. This Luxman is worth it and I learned a lot...maybe more than I expected and that's good, too.
But I would like to have a nice 'chat' with the "Epoxy Man" about a thing or two. Good luck to all home techs. :thmbsp:
