In the very beginning of this hobby for me I ran into several vintage units, where previous owners installed inline power switch because original in the front panel was either fused or failed otherwise. Installing relay was the reason to protect AC switch contacts. Some older VW starter solenoids were fed directly from the ignition switch causing premature ignition switch failure and often meltdown. In early 2000s, whenever I was replacing ignition switch, I started installing relay to power the solenoid. What do you know! Shortly after there was a recall or TSB describing this condition. Since then, every starter or ignition switch sold for affected model comes with the instruction sheet, referencing to "ACC" relay kit.
Back to Fisher world.
Please note that I have not made latest PI modification changes yet. For the moment, goal is to get voltages correct before any other changes are made.
Wall 122.6vac
With both CL-80 bypassed and outputs tubes biased at 21mA, B+ distribution as follows:
437v, 386v, 355v, 312v, 218v
AC heaters are at 6.59v
Screens are at 315v
With single CL-80 in the circuit and output tubes biased at 21mA, AC heaters are 6.46v, main B+ is 423v and screens are 304v
I think first scenario without thermistors shows desirable voltages but offer no protection in the event that wall voltage climbs. 6.59vac is pretty close to +5% limit (6.615vac)
Are there other thermistors that I could try that would be a better compromise?
EDIT: 2 x CL-80 in parallel? Or I'm overthinking it?
It's worth noting that my power supply is not modified as was suggested by @sony6060 but all can capacitors are new from Hayseed. There is no choke either. The only difference from stock form is R41 @ 2.2k.
Thanks for your help!
Wall 122.6vac
Screens are at 315v
