yup, it sure seems like the right tool for the job... it should fit right on there (screw pattern looks to be the same)... it should produce some pretty good sound... and it should be pretty easy, which is an important consideration for version 1...
re: lighting. that's a good point on the led's, and something i didn't think of. i was thinking that led's would be a good choice for coolness/energy efficiency, but the lack of diffuseness would be a real problem with backlighting.
1) top plastics are probably lit by 44/47 bayonet bulbs (can't tell, mount is missing, but i'll look it up in the service manual). these were used in a LOT of coin op machines for a long time. i'm sure they were originally 44's. 47's replaced 44's as they ran much cooler, but not until long after this machine was out in the wild.
link to specs on 47 bulbs
2) the dome illumination was provided by a "standard" incandescent bulb. this sits in a little rotating cylinder within the dome. the rotating cylinder has (or more correctly, had) a covering with colors on it.
3) the side plastics look to be #81 bayonet bulbs. again, they were probably something different "back in the day", but went to a more "modern" bulb (the 81) somewhere along the line.
link to 81 bulbs
4) coin drop is likely 44/47's as well. i haven't gotten the control mechanism completely apart yet, as i'm taking
careful notes along the way of how it came apart, so it's taking a long time.
possible incandescent solutions might be:
1) replace the top plastics/coin drop with what is there. same deal on the coin drop. i've got #47 bulbs and sockets lying around as spares for my pinball machine. i should be able to cannibalize the transformer out of the "parts pile". assuming i can identify it and it works.
2) i can get the entire dome "animation" as a repro part. i need to get a few new pieces for that anyway, so to get the entire thing would be a minimal increase in cost.
3) the big plastics. there's a couple of options here. i could just string together a "new" string of 81's (or something close). that's just patience work, and i could draw power from the same transformer that is used for the #47's. i also might be able to cannibalize a string or two of christmas lights so that i don't have to make the new string, but socket fitment in existing hole would be a problem there.
all of the above assume new wiring. i don't dare put any of the old stuff back in there.
i wish i could figure out a way to replace the big plastics with something else. that repro set costs $375. :tears: and used ones are not available, period.
