It seems if a recording of the the same source material was played through several mediums (with the same amp and speakers), it would sound best on the medium where the signal-to-noise ratio (SNR) is the highest. After all, the signal would be the music, and the noise would be everything else. If that simple analogy is true, it follows that a high SNR would correlate with high quality sound reproduction.
By looking at specs of gear that I've had, have, or heard, I came up with these approximate SNR figures for turntables, cassette decks, tuners, and CD players. I didn't look at DACs or other devices used for streaming, just the old school stuff. Nor did I look at R-2-R decks.
Cassette Decks
It seems 75 dB SNR is pretty good with noise reduction (Denon DN-790R, some JVCs, maybe some Naks but the Dragon is only 72 dB) so let's use 75 dB for cassette top end.
Turntables
I've heard TTs that get to 80 dB, but I don't think any of the highly lauded Technics tables did. Best I've owned was 78 dB. Let's use 80 dB for TT top end.
Tuners
A lot of tuners are in the 60 to 80 db range, but many go 90 db or higher, including several Yamahas (T-2, T-85, TX-950, etc.). Obviously you need a strong signal and/or a good antenna. But use 90 dB SNR as tuner top end.
CD Players
Everything but the early players go over 100 dB SNR. I've had several spec'ed at 115 dB or higher (Sony CDP-X229ES, and some Denon DVD/SACD players). So lets use 115 dB SNR for CD players.
The ranking then for sound quality of good gear is CD #1 (115 dB), FM Stereo Tuner #2 (90 dB), Turntable #3 (80 dB), Cassette #4 (75 dB). That order sounds right to me in terms of sound quality, although I like the sound of a tape recorded on a good deck, so I might flip #3 and #4.
What do you think?
Cassette Decks
Turntables
Tuners
CD Players
What do you think?
