Shrugg
My Sony Ps- x50 developed a few problems after using it for about a year. The strobe Light had failed and the table ran slow on 33, and even slower on 45. I recapped the power supply, which fixed my stobe issue, but didn't fix the turntable. I was stumped.
After much head scratching, I went achead and adjusted the speed trimmers. The 33 rpm trimmer made no affect, but the 45 trimmer was a different story. Even though it had visible corrosion, I thought it would have no effect, as it hadnt been adjusted for 40 years. Even so, lo and behoold, the table immediately quartz locked and played at the exact seed, and hhas been doing so ever since.
So the moral of the story is, if you're fixing a turntable and get stuck, CHECK THE TRIM POTS!!!
