105.1 owner too. Have the sales slip and manual. Numbers: 2784 A/B. Have not done a full recap but have replaced a few failing caps couple years ago thanks to PE. Scored a Hafler XL-280 amp which really mates well with these.
Here's what I did. I traced the off-sound (like an out of tune FM station) to the mid so changed the ones that tested dead - did both sides to keep things equal.
Interesting - looks like the 30 and 100 uF caps from the schematic.
Also, there are a few surface scratches on both cabinets, is there an oil that will enhance the finish and also hide the marks?
@avantbored I can attempt to answer your questions.
1. Can't answer it, as mine are MK1 (rev 2), and the kit comes with all of the capacitors for both versions of the MK1.
2. It's straight forward, but before you do anything, make sure you're testing them correctly. Set the crossover dial to the "listening window" mode and play white noise. Then slowly turn up the volume until the LEDs begin to fade-in. Be careful, as these old LEDs can be quite dim. If it's still no good, read on. Remove the top speaker enclosure from the bass cabinets, then remove the 6 screws on the back of the top enclosure, as well as the nut holding the adjustment dial on and the tilt adjustment (it unscrews). Once the back cover is loose, push the potentiometer out of the plastic casing, and you're left with a daughterboard pcb which is attached to the LED / crossover pcb by jumper wires. These simply unclip. Lift up the board, and check that the LED is still in its place. It should be in a small u-shaped dish looking thing with a hole in it for the LED to sit in. If not, try repositioning it. If it's still not working, check continuity at the connectors and try running some current across the leads to get the LED to illuminate. If all else fails, replace the LEDs. I recently replaced mine, as my original ones were far too dim and the wires were too short (imo). It should take less than 40 mins per side to do all this.
Good luck!
I would fill it with epoxy or epoxy mixed with sawdust, sand flush, then redrill the hole. There is tinted epoxy putty out there but it would probably be too brittle once cured.Greetings KEF 105 friends.
Writing to see if any of y'all have a solution for my 105.2s -- the caster on one of my speakers is loosey goosey. The wood has started to shred away from where the caster is installed -- how might I go about repairing this? Pics upon request, as I don't want to move the speaker around too much (and I'm listening right now).
Cheers, all.
Just got mine 4755 a/b (105.1). I`m going to need to upgrade a few pieces....my CD player (rotel unit) sounds horrible with them, my streamer on the other hand really makes a difference, not entirely sure why but anything played through my CD player is flat, lifeless, and devoid of base. My amp seems to be subpar as well....
Pro amps are always an option with the big power hungry speakers. I did that with a pair of Tangent RS8s years ago. I was putting a system together for my brothers best friend based on the RS8s. It took me many tries before I settled on a Yamaha P2100 amp paired with a Pioneer SA-1000 for the preamp in order to get the system within budget and about a year to do. They worked quite well together!
The preamp is really the important part to see. You could install the pro amp out of the way in a cabinet or something like that, and put a quieter fan on it. All good!
I would start with the amp, and see where things take you from there. I've even had a preamp change on my above mentioned RS8s that completed changed the speakers. So start with your amp, and get that fixed/replaced before changing anything else.
