It's sweet to get ahold of that cartridge also.Just what I needed - thanks xbart and 4-2-7!
van den Hul MC-10 Special: $1200
The MC-10 Special is a recent upgrade of the MC-10, the main difference being a magnet mod that ups the output and increases resolution. The upgrade is available to MC-10 owners as part of a $500 "re-tip." The MC-10 comes with the most elaborate packaging and documentation, including a custom frequency-response printout and the traditional wooden casket—er, box. According to the printout, the MC-10 Special is flat between 25Hz and 12.5kHz, with a 0.5dB drop at 20Hz and a 0.5dB rise between 16kHz and 20kHz.
Fitted with van den Hul's patented "Miter" tip (over a million sold) and a solid boron cantilever, the hand-built MC-10 Special is designed to track at between 1.35 and 1.5gm. I tracked it at the upper limit, loaded to 1000 ohms. vdH lists the load impedance at "100 ohms – 47k ohms (optimum 200 ohms, up)."
Read more at https://www.analogplanet.com/content/analog-corner-32#yiXy6KhrQ1p2CySj.99
