The SMSL M500
OK, so you need to have a few th8ngs in place to play DSD through foobar2000. Foobar2000 is a modular playback program so you need to go find and download components that you then load in foobar2000 on your PC. So you will need the SACD decoder add-on, you may add other add-ons for some other file types like DVDA for example.
Also you need to install the ASIO driver set for the M500, and I think there’s a firmware patch maybe? I can’t remember offhand but probably. And there’s an ASIO component for foobar2000 too.
if you have an iPad, I recommend trying MonkeyMoteHD. You also need to install the add-on for that in foobar2000. It’s super convenient and a great way to control playback via wifi. You can quickly scroll through large lists, it’s great.
https://diyaudioheaven.wordpress.com/digital/pc-software/foobar-2000-for-dummies/
This is an example of a foobar2000 tutorial. There are videos on YouTube and such. Once you get the hang of it, it’s not bad, but there is a learning curve. After you have your components installed it’s a powerful platform and it sounds great.
I also recommend milkdrop 2.0 visualizer, although the install is tricky, I’ve had struggles but when you get it set up properly it looks wild. And I would look into some quick tips for optimizing your audio output on a PC, there are many threads and web sites on the subject.
After all the components are in place, there are settings that you need to adjust nothin Windows, and in foobar2000 that coordinate the proper output to the DAC. It’s not plug and play with foobar2000 but it’s flexible, there’s a ton of options, from driver options to EQ’s to bass/subwoofer management, ripping, converting, and on and on.
If it’s too much of a time suck, you can buy software like jriver for example that I think is more plug and play. Foobar2000 is barebones and you build it out as you need to.
https://www.foobar2000.org/components This is the foobar2000 components repository. You can download most of what you need from here, and some stuff is posted elsewhere. Just google to find stuff.
https://sourceforge.net/projects/sacddecoder/ This is the SACD plug-in.
Good Luck!
BTW, foobar2000 is what I use for hi-res surround playback too, works great via HDMI to a home theater receiver, although you cannot pass native DSD that way, but the sound is still very good, 24/192 and in 5.1 surround. I think when you do have the M500 properly coupled and DSD going through it, you will be pleased. I think it sounds excellent.
For the last 4 years now, I own an SMSL M500 Mk1. In the input side of things both my Samsung TV (SPIDF) and Mac Mini (USB) are connected to it. My Abacus active speakers are connected to the XLR outputs. Also permament connected is along cable for my Shure SE535 earbuds. Overall is has been very reliable. It sounds really good in my ears. Weakest part for me is the remote control. It works, but only if you press the buttons firm and aim it exact at the DAC.
In my home office I use SMSL Sanskrit Mk1. Also a nice sounding DAC for smaller budget.
